Mar 24, 2012 #1 J jimski In over my head Joined Apr 26, 2008 Messages 1,019 1/2 slide shift use to be firm, 2/3 shifts still extremely positive, 3/4shift positive also. Accelerate and overdrive flare. Any ideals?
Mar 24, 2012 #2 S SSedan64 JoaTMoN Joined Dec 8, 2007 Messages 1,590 Accelerate and overdrive flare?? Does this mean 1-2 slides/slips worse or 3-4 shift flares? Possibly 2nd/Intermediate Band, Servo problem or 1-2 Accumulator problem.
Mar 25, 2012 #3 J jimski In over my head Joined Apr 26, 2008 Messages 1,019 SSedan64 said: Accelerate and overdrive flare?? Does this mean 1-2 slides/slips worse or 3-4 shift flares? Possibly 2nd/Intermediate Band, Servo problem or 1-2 Accumulator problem. Click to expand... SSedan64 said: Accelerate and overdrive flare?? Does this mean 1-2 slides/slips worse or 3-4 shift flares? Possibly 2nd/Intermediate Band, Servo problem or 1-2 Accumulator problem. Click to expand... when u step on it in 2nd gear over drives kicks in and it flares, i guess it is 1-2 flare
Mar 25, 2012 #4 B bison Moderator Staff member TurboBuick.Com Supporter! Joined Dec 19, 2005 Messages 18,053 jimski said: when u step on it in 2nd gear over drives kicks in and it flares, i guess it is 1-2 flare Click to expand... You cant get a 1-2 flare. In order to get a flare you have to be releasing something. You cant be in 4th and 2nd at the same time either.
Mar 25, 2012 #5 J jimski In over my head Joined Apr 26, 2008 Messages 1,019 bison said: You cant get a 1-2 flare. In order to get a flare you have to be releasing something. You cant be in 4th and 2nd at the same time either. Click to expand... 2nd gear slips and won't hold under throttle 1-2 slide shift use to be firm 2- 3 shift still firm 3-4 shift still firm
Mar 25, 2012 #6 turbo nasty Turbo Dojo / MNTR Joined Jul 19, 2001 Messages 9,478 Your description is confusing... Bet the second gear band is done if your 2nd gear doesnt hold and the 1-2 slide shifts
Mar 25, 2012 #7 B bison Moderator Staff member TurboBuick.Com Supporter! Joined Dec 19, 2005 Messages 18,053 The band and drum are likely toast. It's possible the servo lug on the band is blown out
Mar 25, 2012 #8 J jimski In over my head Joined Apr 26, 2008 Messages 1,019 bison said: The band and drum are likely toast. It's possible the servo lug on the band is blown out Click to expand... I have to pull this crap out again, well it is the luck of the irish . Im thinking just the same now u mention it band and drum is junk
