black owned
black pride
- Jun 15, 2008
more talk on these 4.1's please.....Just to clear things up , your not talking about a production 4.1 in the above statement are you?
Thanks, Kip
Thanks, Kip
Thanks, Kip
What he said, is this a production block or Stage motor.... Inquiring mimds want to know if these 4.1 production blocks can see those numbers
Yes hes talking about a production block he says it on the post 8 (I then built the first TA alum block 4.1 and sold the complete production 4.1 engine to an owner in Cali. After a few more years I heard from the third owner who was still running the crap out of it!)
can anyone help me in this area?i was thinking of doing a 4.1 with stock 3.8 crank & rods ported irons 212/roller 80lb.inj. & 6766 turbo. .I was running this same combo at 27psi boost in my 3.8..what would be the ups & downs of using this same combo in a 4.1 & should i use my stock manifolds or hooker headers that i have...?please give me all of your valuable input on this....
whats your combo consist of?Thankyou for all of your replies . I've since did the 4.1 thing . My motor is done & will be in my super beautiful car in the next 2weeks or less. I had a lot of help n support n parts from Nick & Bison . I will keep u all up to date n will go into detail about my combo after I have some track numbers to compare to my 3.8 .I put all of my motors on kill I race a lot for money . This motor will not be babied. I will let all of you know just what this motor is capable of doing with time slips &youtube videos.
specs on the pistons?stoc length rods?Ok the 4.1 is all togather now in my car &running . So far I was able to put 50 miles on my motor today due to the nice weather here in Det. Right now I'm just taking it slow n making sure all is well far as leaks n stuff like that ... Proper break in. The motor feels silky smooth sounds electric almost. At very low boost 7psi it feels just so strong. If this motor holds togather n works well I'm not ever goin back to a 109 block .Size matters this 256 feels real good . & the cost wasn't bad for pistons because I have a 4 inch bore .. Chevy pistons from Ross .My combo is a 35 over 4.1 9:1 compr fully ported irons 215/220 comp Hyd rllr 80lb injs & tt chip preci plenum fmic 6766 cea hoffer built 200r ptc nl atr headers n down pipe 3in / 3in atr exh..Next on my list is the racetronix dp. Again thanks to all of you for being so helpful & your continued support.. Aggressive Performance.
Very nice build...nice and simple! ...this will be my direction on my next motor. Which crank did you use? where you temped to stroke it?Ok the 4.1 is all togather now in my car &running . So far I was able to put 50 miles on my motor today due to the nice weather here in Det. Right now I'm just taking it slow n making sure all is well far as leaks n stuff like that ... Proper break in. The motor feels silky smooth sounds electric almost. At very low boost 7psi it feels just so strong. If this motor holds togather n works well I'm not ever goin back to a 109 block .Size matters this 256 feels real good . & the cost wasn't bad for pistons because I have a 4 inch bore .. Chevy pistons from Ross .My combo is a 35 over 4.1 9:1 compr fully ported irons 215/220 comp Hyd rllr 80lb injs & tt chip preci plenum fmic 6766 cea hoffer built 200r ptc nl atr headers n down pipe 3in / 3in atr exh..Next on my list is the racetronix dp. Again thanks to all of you for being so helpful & your continued support.. Aggressive Performance.
