3" Hot air down pipes with integrated waste gate
Brent, what downpipe are you running now?
as of right now nothing. im having something made soon, you will have to wait and see once i get it made. it will be an external gate setup with a AMS500 and a custom dp :eek:
so now that you have them made brian, you want to sale me mine back ;)
here is a picture of what it will look like. they built the downpipes using my old one in these pictures. hope this helps. mine has a hole in it for the use of a wideband so disregard the bung. it will fit with the a/c and its more then you will need. o and if you want to get real crazy you can easly set it up for a external gate.
one other thing. my 5 dollar rattle can held up better then my jet hot coat you see on the up-pipe :eek:
BOOST231
Who's 5 dollar rattle can did you use? Hi Temp Rustoleum? Bar BQ hit Paint? I need to touch up my Poston jet coated header. You 5 dollar rattle job does look better than both our jet hot coated parts......
Actually you will have to speak to Rod about that ;) We are getting them in either Friday or Monday depending on shipping. I'll get some pics up when we get them in.
TTA pipes are next. :cool:
BOOST231
you know i wish i remembered. i got it from checker auto parts.
How many sold so far? I am still waiting on my income tax to show up.....:mad:
5 sold & 1 waiting in the wings if some one backs out. Problem is these are being built the same time we are getting the 86-7's so there have been production delays for both.
lets see some pics !!
stainless option? so i guess you got my DP ok then?
We will get some up soon. It is the same Pipe I worked on with mease back in 2001. Just found some one else to do it.
2 sold so far. That is why we only are building 5 or 6.
BW,
Still waiting for some pics ....... and stainless option question.
Also, never stated if this will fit with the AC, Stock/Poston headers, connections (Slip-on or other), one/2 piece, coating, etc. ......... maybe I missed it ........ :smile:
By the way, THANKS for supporting the HA cars and enthusiasts!
If the 1 back up is sold, how long would it take to build me one? I had to file taxes in 2 states: ALABAMA:mad: and KENTUCKY:mad: . The IRS is the NEW MAFIA....:mad:
the dp was made after mine. it will fit with the a/c and will work with all headers. as far as stainless still not sure
Next question is...are these coated in any way?? What is the finish on them? (Ceramic-bare steel-jet coated)??? Brian...I am VERY interested in that last one...;) ---Keith
3" Pipe received and installation attempted...
So I received the down pipe last week and attempted to install last weekend. Alright, so this is one clean pipe. Smooth bends, clean welds, truely a good quality pipe.
But people, whoever said this thing fits with the heater box in never mentioned the serious heat shield modification involved.
I am trying to install with the motor in. I had to cut the old pipe out, impossible to remove intact. The old pipe is double walled?!?! That's like a 1 3/4" I.D. pipe. This new pipe is going to make a world of difference!
The heater box heat shield is shaped so I can't pull it out from the top or bottom. So I took a hammer and beat the crap out of it on the car until the pipe fit. Well, if you consider bolting it up but rubbing still, I'm done. Unfortunately, I don't.
For fun, I started it and enjoyed the sound of "open headers", then shut it off before it got too hot.
Next step is to take it all apart, beat on the shield a little more and try to make it fit. I'm looking for at least a 1/2" clearance.
Thanks Brian!
Thanks Brian!
Understand one thing, by beating the crap out of your heat shield you are probably busting up you fiberglass heater box. May as well just taken it out and be done with it. Anyway the real problem is that your body bushings are worn out. If you had've replaced them that would give you at least 1/4-1/2 inch more clearance.
Beating is figurative...
I'm not really beating the heat shield to the point of breaking the fiberglass. Being in Southern California, I need my A/C, and I'd like to start driving the car more often. Replacing the body bushings makes perfect sense, raising the car from the frame, increasing clearance. Thanks for the tip! I'll post back with my results.
Thanks Brian!
This pipe isn't like an 87 where you can move it an 1/8" & change the clearance a whole lot. Before you get crazy beating the heat shield make sure everything is correct as far as motor mounts & body bushings. I know you have to bend the A/C line about an 1/8" to 1/4" if I remember correctly. I helped build this unit back in the early parts of 2000, I think. Been a while.
It is a 2 piece & it is stainless. Like our 86-7 pipes it uses an RJC flange & puck. The flange may be an 1/8" thicker then the older units.
On a side note I do have 4 more here. Just arrived today. With shipping I will be raising the prices up slightly. about $25.00. I wanted to get these out there & see how they sold. If we can get 10 more going at a time we may be able to do better on the pricing. It is just not worth doing a few here & there.
I had a pic taken today. I will post it up tomorrow. I do apologize for not being more active in this post we just have been really,really busy.
mrfixit49 post up a pic. May make it alittle easier to see what you are going thru.
Pics...
I didn't have a problem with the A/C line, just the heat shield. The bushings show wear and could stand to be replaced. So far I have been very pleased with the pipe. I understand custom work requires custom fabrication. I love the side by side shot of the old down pipe next to the 3" straight piece. Thanks again Brian. Hot air owners without one, get one while they last.
