fullahotair
- Feb 26, 2002
Some of you might have recalled some issues a friend of mine was having with a 327 that he just had rebuilt. Well we found the problem....just not sure what the cause is. Keep in mind this motor has 30 miles on it tops.... The builder is speaking with the manufacturer to get their input.... Pistons in the #5 and #8 cylinders were busted. I imagine one broke up first and then transferred over to the other cylinder....
Would you expect to bust up a piston like this with predetonation or ignition knock for a normally aspirated motor considering it was never wide open on the throttle? It has edelbrock performer rpm heads. I think i remember being told the compression ratio was 10.5 to 1 - i might be wrong on that..i'll have to check
Bad piston?
engine ate something?
Just curious as to what your thoughts are...
Thanks,
Nate
Bad piston?
Thanks,
Nate
