What injectors and engine management is he going to be running?
The car has a classic FAST with 83#ers
This car has already run 10.35@ 130 weighing in at close to 3800#s
This is the same motor we are stroking.
SignUp Now!What injectors and engine management is he going to be running?
This is a non stage block,The guy wants to test the limits of a production 4.1 block. /QUOTE]
This was done many years ago, about in the mid-90', before there were "boards, he was on the GNTTYPE "list" and we had a great discussion about his project.![]()
A guy, Fred, wanted to build a killer 4.1 for a hybrid use, and did not have the availability of the many after market forged, and other parts to help durability. With his build, he obtained over 700 HP on an engine dyno. True to his word, just north of 700 HP, it failed.As I recall, the block gave up?
Based upon his "inspiration", I then built a 4.1 block that was given to me. It had a cast crank, stock rods, a girdle, hard block and alum heads. Using Felpro 1026 head gaskets, this was a very reliable mid-10's combination using a TE-45A.
We have done a few 4.1's since then, not stroked though. With good heads and other parts combo, the problem with a 4.1 build on the street, is so much low end torque it is hard to keep the tires from spinning even with good rubber!![]()
The 4.1 stroker we are finishing has all forged internals, hard block, good flowing alum heads with receiver grooves for use with copper gaskets and an o-ring in the block. We expect this combo to run reliable high 9's with a GTQ-70 turbo.
Based on info from other local GN's we have done with 109 blocks running high 9's, we should need only 20-21 psi of boost. Since we will not see temps below 100 degrees at the track until September, it will probably not be run before then.
Nick, what do you think about the use of Hard Block in a street 4.1 motor...maybe about 1/2 way up????
I am new to the hard block concept, meaning I don't quite understand it's purpose although I have heard of quite a few people using it.
Can this be used on a street car or will the engine have trouble cooling? And is the purpose to eliminate cylinder wall deflection? Just trying to think of it from a theoretical stand point I don't see any other advantage.
Additionally in horsepower, what does it take our full weight cars to get into the 9's?? I was looking at some stuff shouldn't we expect around 1.5 HP per cubic inch and with 274 CI that is around 390 - 400 hp and then double the atmosphere with an efficient turbo. Won't that net you roughly 700 at around 14 - 15 psi?
Reason I am asking is I have a 4.1 stroker going together with a set of the champion heads and the RJC girdle and I am thinking that if the tune is on point the thing should #1 live and easily make north of 700.
+1You guys are giving me some good info for my build. I'm still watching.
subscribing![]()
Mat is supposed to pic up his shortblock this weekend and drop it off for me to finish assemble
I was at BPG this weekend,Mat was gonna pic the motor up.Otto, any updates on this project?
