Thanks for the reply Nick, looking forward to getting my Stage II back from you. Looks like I'll be getting headers and a DP from you too. So what do you think of a 71HPS turbo for my set-up? Thanks!
Th only reason this community runs 3 bolts is becuase Terry Houston made that downpipe back in the day and made it easy to bolt on a big turbo. 4 bolts always work better just tougher to install.
Mike
Mike
Mike
X2.....I 've been running 4 bolt exhaust housing on my car since 1992 on the street around 50K miles...no issues at all with pin point boost control with an external gate at the collector of the header.
I also have seen people with boost creep issues with a 3 bolt turbo and 3" to 3.5" down pipe and external gates. The new billet turbos move so much air as they are so efficient, it's much more harder to control boost with 3 bolt setup. Just recently, we went through hell and back with a billet 67/65, a 3.5 DP with 46mm waste gate and 3 bolt housing ported to hell, we did everything to maximize the flow and still had boost creep. We went to a four bolt housing and waste gate below the turbo on the collector. Now we have pin point boost control, less back pressure in the system as well. No track times yet
I'm running 3 bolt personally with external gate dumped and on spring it doesnt creep any. It does creep a little with my rjc controller hooked up though, but only about 1.5psi max.
