50's for a distance
turbo buicks
ESADAH!!!
ok im getting injectors soon and my mind is set on 50's and im not changing that. my question is if i put them in at my friends house will i be ok to drive to my other friends house approx. 20 mins away w/a stock chip w/o any problems? no "getting on it" or anything just normal driving.
I don't think your car will start. If it does start it will probably flood with fuel immediately. :eek:
hmmmm...if this is true maybe i need to install them at my other friends house:) my friend can custom burn chips for me. can a chip be burned for 50's w/o having them in the car so i could put it in and then go to his house and get it tuned correctly?
You could still use your stock ECM as long as your chip has been program for the 50's. I would have a chip burn for the new injectors before I even decided to turn the car on.:cool:
You are gonna be idling (if it idles) with BLM's and INT's pegged!! Chugging with black smoke out the tail pipes! How do I know? I accidently was shipped a stock injector chip instead of a MSD-50 chip.
