Originally posted by 1000MileStylez
MSD weld in bungs, and Accel fuel rails
My store sells both, we got the rails in stock , the bungs we got to order, if you want, call up 516-766-2225 ask for kenny he does over the phone ordering. unless your in new york, come down to SK speed in rockville center, ask for gabe
hth
ps, we got a variety of XRP fittings, we can get you hooked up
Originally posted by Louie L.
Yes that will be fine. I use the stock return line from the regulator into the frame rail then into the stock feed line with no probs.
I feed the stock rail with a -10 line and a Weldon 2015 pump. Never had any return problems.
Originally posted by salvageV6
"Low 12's to high mid 11's"
I wouldn't waste your time until low 11's.
But -8AN should work fine if you need a project.
on you fuel rail do you run the regulator before the rail or after the rail with the balance line and run the return from the bottom of the regulator
thanx louie
-Gabe
