"Quote"
I currently have a kit to correct the geometry when a 12-bolt is installed and I have a few other kits in the works too.
Kevin, do you have a kit available for a Ford 9" in a '87 Regal ?
George
Thanks Laz,
I realize this. I was just checking out the ears on the Moser 9" to see if they were raised and how much from the stock position. I saw that they were and just wanted to see how much of an angle the UCA's had. I was just surprized that they were different and wanted to check with the experts.
I'll now proceed in the recommended fashion to get it close ( in theory at least ) and I'll fine tune it at the track. 60 foot time slips will be my report card. I'll be happy if I can get into the 1:20's This will get me well into the 8's.
George
George,
If you have 8 sec potential your going to have move the mounting location. The Moser rear puts it 2" higher than the stock location. IC will be just in front of the rear. This is going to crush the tire on a tranbrake launch, so much so that it will distort the contact patch. Amongst other issues... Ask me how I know. You dont need that much hit from the suspension with 8 sec power. Also with the IC in that position its going to cause car to bunny hop on the leave. I just had new brackets made on mine to adjust the uppers where I want. It gives me 4 holes to adjust. The highest being still 1" lower than it was before with stock Moser mounting location. If you need any help tuning it just let me know.
For the CG, yes.
For the control arm mounting points, I think the riding height on the stock GN example in my sim might be too high. I would use Blazer406's numbers or make your own measurements. If you'd like, post the numbers you get and I'll run them through the sim and get the results back to you. The more people that volunteer their pickup points for the control arms, the better chance of coming up with a dependable spec to use for our cars.
That sounds good George. I'll use your numbers.Don,
The measurements for the length of the control arms I did with a plumb bob. I marked the floor where the bob pointed and measured the distance between the marks, squared to the framerail, not on the angle that they sit.
I just used the centre of the mounting bolts as a reference for the string on the plumb line. Does this make a difference ?
George
"Quote"
Don,
Here are my numbers;
RLCA rear point = 9 1/8" off ground
RLCA front point = 11" off ground
RLCA length 18 3/4" bolt to bolt
RUCA rear point = 21" off ground
RUCA front point = 19" off ground
RUCA lenghth = 7 1/2" bolt to bolt
rear weight = 1536 lbs. or 43%
Thanks, I haven't been able to weigh it with the back end up "yet"
George
George. A few questions:
What's the diameters of your tires?
What is your ET goal?
What is the weight of the car?
Are you planing to leave on the foot brake or trans brake?
Good question Laz. I've just did some modifications on my brakes in order to allow me to build boost on the footbrake. I've changed the pedal ratio, installed a smaller bore master cyl. and removed the combination valve to give me full pressure to the rear.
The idea was to get up on boost in the pre-stage lite and bump to stage. Then to transbrake.
I'm thinking that if I can control boost with my AMS1000 controller, I should be able to launch reasonably by timing when the full boost comes on; approx. 1.2 or 1.3 seconds, ramped ( I could be flawed in my thinking though)
Again, your opinions and experienceare valued.
As Don pointed out, with rear end rise, the dynamic IC should be much more favourable than the static #'s. What do you think ? I haven't launched the car with more than 10 lbs boost yet. Car seems to plant tires OK at that level of boost.
George
