6262 spool
Keep an eye on fuel pressure running 28psi with a small 255 pump that's in your sig.
That was my concern and reason for the question. I also have the the 255 pump and 60# injectors and I get concerned when I run in the high 70% at 26# boost.
Copy that I'm kinda concerned about that thinking about upgrading .but the next upgrade is a dbl pumper witch is $$I think there's more in it now with just getting the 60 down .....Oh well its winter here now ,there's time .thanks
What does your car weigh?
28#and c16 10.2 afr
You are running C-16 with afr of 10.2. Is that awful rich? I ask that because I run 93 + alky with a 10.6 afr and I consider that rich, Does race gas require a different afr? Just trying to learn if there is a difference in requirement.
I think it is but when I lean it out even a little the mph goes down I tryed it on several occasions
Thanks for the response. Your mph is fantastic so you sure don't want to slow it down. I wish I could gain three more mph in the 1/8.
Yeah. The mph is awsome I've never driven anything that pulls like this thing does .I took a friend for a ride the other day and he couldn't believe it .and he's driven some fast cars .Iover that I can drive it around on low boost anywhere and get 15 18 mpg .and when you Wana ay dump in the good stuff and hold on
