C
coach
Guest
OOH...I gotta see more of this!!! Mike is a serious fabber, like myself.
SignUp Now!Probably not. I have 4.5" on there and built the rearend to fit them. If you want the same fit with 5.5" backspacing, you would need a rearend 57 1/4" wide. I think a stock g-body rear is 57 1/2". You would need a frame notch with either setup. Mine really needs mini tubs and some fender lip trimming to let it sit any lower.
Vector 8.5" are 3 & 5/8" Donnie. If you want a pic to prove it just say so.![]()
since there isn't going to be any more show car, restoration/ body work content.
Should give it a grey stripe and make it WH1.![]()
Mike,
Good looking GN, but kind of bummed you went a different direction from the WH-1. The GN looks like it will be on the road a lot quicker than the WH-1 though. The good thing for you is that the Hot Rod Power Tour 2013 will be in your neck of the woods and maybe we can get together again. I have yet to install the tranny fittings you milled or the e-brake brackets, but I have installed the vacuum block.
