ExactlySo the bracket mount to the block then it's mount to the frame mount?
SignUp Now!ExactlySo the bracket mount to the block then it's mount to the frame mount?
Stock 5.3 onesWhat lifters are you using. I read that they use LS7 lifters will work great
No , per the Hooker instructions it says 78-87 g body v8 clamshell engine mountsOk. I see. I just score a 6.0 short block for $500 out of 2004 Denali. My question for you is the adapter plates you use goes on the the stock v6 frame mount?
Awesome on the 6.0 short lock , this all is a first for me . I'm doing this all off reading other people's builds on this forum . I have read every one 3-4 times to try to learn everything I canOk. I see. I just score a 6.0 short block for $500 out of 2004 Denali. My question for you is the adapter plates you use goes on the the stock v6 frame mount?
Sure doYou have the parts # for the Hooker motor plates?
What are you putting the 6.0 in ?You have the parts # for the Hooker motor plates?
Damn ! I hope these mounts are not the problem . I have read some builds that you have to relocate the passenger side coil so it does not hit . My buddy owns a shop and is a unreal fabricator and will be helping me with fitment issues . I wonder why the trans is hitting the tunnel ? I have read many doing the 4L80E without problems and using these mounts . I hope you figure it out and please post if you do and if I find out sonething I will post as soon as I get thereCurious to see what you do for the A/C. I have pretty much the identical set up you do. 6.0/4L80E/ holley/hooker engine and tranny mounts. Im running the CTSV pan as well. I have my engine and tranny in but my passenger side valve cover coil mount is digging into the A/C box... With the transmission in, my tranny is hitting the floor and the valve cover is barely off the AC box... I know with the truck accessories the truck AC compressor won't fit unless the engine xrossmember is cut. Im gonna try a different route but have to wait till Monday to talk with LSSIMPLE on a bracket set up.
Nice85 TType
