OK! Today, some new records for the car.
The best run today:
1.297 60 ft.
3.704 @ 330 mark
94.397 mph @ 330 mark
5.732 @ 660
MPH not worky dirky on this run.
A few runs earlier:
1.430 60 ft.
3.886 @ 330
MPH @ 330 mark not worky dirky. Again
5.932 @ 660
120.269 mph @ 660
And my wife says the car looks like a snake going down the track.
The best run was done with a pretty warm nitrous bottle. The sun was beating down on it pretty good, even though I had it covered in an effort to keep the temp down. Pressure in the bottle was at around 1000 psi. I normally run with 900 psi. I REALLY LIKEY 1,000!!! The wheels carried to the tree. So I was told. I run the nitrous system on the rich side for cases just like this. Sometimes there will be a time where the bottle temp gets high, and when it does, I don't have to worry about the mixture being too lean. It'll just end up being PERRRFEEECT!!!
:tongue:
Some interesting tuning notes. I ended up tightening the wastegate spring tension adjuster to the end of its travel. This is with the spring combo that is meant to be used with a boost target range of 127.5-166.7 kPa. I did this in search for a consistent 31 psi boost level. At this setting the boost recorded a 29-30 psi boost through the entire run. Keep in mind, I'm using manifold pressure for boost control. Not an auxiliary pressure supply. During inspection of the engine I noticed a mess around the plenum pop off which I took as the setting of the pop off being too loose and allowing boost to escape. During lower boost targets of the past, I did'nt notice any mess around the pop off. So... judging by the spring combo of the wastegate, is a low exhaust back pressure producing enough cfm from the compressor to maintain a steady 29-30 psi boost on top of the volume of air that is being lost through the plenum pop off valve?
The next test is to tighten the plenum pop off valve and back off the wastegate spring tension adjuster.
I know. I need to get that BP gauge mounted. Just thought you guys might want to take a guess on this one.
New boost target. The last run of today I had the boost controller set to 32 psi. Hopefully, this will give me a fluctuating boost of 30 to 31 with spikes to 32.
The mixture has been leaning a tiny bit with the new boost level. It's still safe. In fact, I think I like this new a/f ratio. It reads out on the O2 as 10.5 to one. It calculates out to be an actual 4.64 to one.
This engine just keeps surprising me.
