EFI fuel control. The fuel pressure is kept constant or rises with manifold pressure in a linear curve in relation to MAP. A smooth and straight ramp up actually, in relation to MAP. The amount of fuel delivered at different rpm/map points is dependent on the amount of pulse width commanded electronically of the injector.
Mechanical fuel control. The fuel nozzle orifices are a fixed diameter. There is no control of the orifice size or how long it's turned on or off. Typically, the fuel is constantly flowing when the engine is running. The amount of fuel delivered at different rpm/map points is dependant on the speed of a mechnical fuel pump, usually driven at half crankshaft speed, which controls volume and pressure, and mechanically or electrically controlled bypass valves which control the fuel supply pressure at the nozzles. The fuel pressure delivery curve, as seen by the nozzle is not linear, but changes in rate, or levels out at different rpm, and in some cases map, breakpoints.
My system being a combination of both in a way, uses pw to control fuel delivery through the electronic injectors using a linear ramp up of fuel supply pressure, and obviously requires a modification of the fuel supply pressure off the linear curve on the top end to satisfy the needs of the fixed orifice mechanical nozzles.
I posted this to hopefully make more clear my fuel delivery problem to some that may be lost with what is happening.
What would solve my dilemma is a device that would modify the pressure rise curve off the now linear path, after 280 kPa (or start sooner for that matter), and make the rise faster in relation to manifold pressure. Isn't that what FMUs do?
