Sorry for the basic questions. I haven't had the time to look through all the pages, but may try later.
Are you using a 76mm turbo or a 91mm? What dictated your choice in turbo?
What is the stall of the convertor? What did you chose such a tight convertor? What is your slip%?
Since you are running on alchol. I assume you aren't using an intercooler? What about a radiator?
Are you having to use the NOS to get a good 60' or is the turbo able to spool well enough without it?
Are you running the NOS dry or wet? How much hp are you hitting it with?
Holy cow. That's quite a grocery list there. I'll try to answer most of them. I know I'm missing an answer for one of them.
I was using an old school T76 with a 200 shot up until the middle of last year. I've been struggling with this Airwerks S510/91mm for more than a year now trying to get the launch squared away. I think I'm really close now. I'm now using a 305hp shot.
This rating is based on the size of the nitrous oxide side jets. I'm using wet port nitrous injection. Six #30 jets.
The choice of turbo was dictated by the compressor map. At boost my engine is flowing just above the middle of the highest efficiency island. As I increase boost in the future the point will continue to rise through the middle of the efficiency islands. Spooling this large turbo was not a concern after seeing the success I had spooling the T76. I knew I had my work cut out for me, but like I've stated in the past, don't bet against me reaching my goals.
If you study the latest video link I posted, you'll see exactly what the stall speed of this torque converter, on and off the nitrous looks like. You'll also see evidence of the als kicking in. I chose this tight T/C due to the planned use of nitrous to kick this thing in the pants. Nitrous was planned for this project from the very beginning in the mid 90s before the import crowd was even turning to alcohol and then nitrous on a regular occurrence. A few years before NHRA even created the import class.
Don't know the exact slip number. I would guess 9-10% at the shifts. Not sure what it is at the finish line. This is taking tire growth into consideration.
I'm still working up on the time while on the nitrous before actual launch with this new tuneup, so I can't tell you how much boost I will ultimately be leaving the line with. Presently, with .7 sec of nitrous before transbrake release, I'm seeing 1-1.5 psi boost right at transbrake release.
I am running a liquid intercooler with ambient temp water. No icing. I know there is a big argument about whether an intercooler is needed or not with alcohol. That has already been argued in this thread with my reasons for using one thoroughly explained.
I am running a radiator. It allows me to run the car to the staging lanes, make my pass and return to the pits without having to be towed. It allows more stable monitoring and uniform temperature control of the engine. It also allows for extended running of the engine to thoroughly warm the engine oil to burn off water and fuel that gets into the oil via blowby. It also makes the car streetable and restricts the driving distance to the capacity of the fuel cell.
