Guys,... I don't want to make the flame thrower so powerful that it pushes the car into the other side wall.![]()
Well point the pipe out the back and it will act like a Jet engine Donnie.:biggrin:
SignUp Now!Guys,... I don't want to make the flame thrower so powerful that it pushes the car into the other side wall.![]()
Well point the pipe out the back and it will act like a Jet engine Donnie.:biggrin:![]()
Or dual pipes out each side for stability. :biggrin:
No, I didn't. A friend invited me to check out the last SCTA land speed record meet at El Mirage for the year, so I went to that. Believe me, there was some internal turmoil going on with that decision.Don,
Did you make it to the track yesterday?
I think if you could get the engine temp up another 5 degrees you'll atomize the the mix better and still keep the detonation out of it Donnie. Looks good so far but I still want to see how she does on the track.
It's a well known fact that as long as an alcohol engine is up to 150 F it'll make good power. I've noticed the same. The engine tone changes right at that temp.
At Bakersfield, the engine was up to 200 Fat the launch, so the engine tune does have good preignition resistance to it.
I don't have total control over the engine temp by the time I launch, so it's common for me to see differing engine temps from run to run. In the past, it's never seemed to make a big difference, but I'll start tracking that more carefully.
It's now Nov. 28th, and it's RAINING! Noooooooooo!
I measure at the point where the collectors from each bank Y together just before the turbo. Even with you measuring close to the head, that would be too high in my book for methanol. Like I said before, I'm not sure how different egts are with ethanol, but my guess is they aren't that much different.Rain, figures huh? Don, where are you measuring EGT(s)? Pre or post turbo? I ask because you seemed to be concerned about my temps. My numbers represent samples 1in from the exhaust ports. BTW, I will be visiting Barona asap to 60ft tune.
