Dusty Bradford
- May 24, 2001
Speaking of 2-step spooling pre-launch. I understand that the routine is different for sticks and automatics. The stick or no-load procedure is pretty well known. A local tuner told me that with an automatic you want to increase timing (50 degrees btdc with gas) and shoot for a power mixture, not particularly overly rich. As the turbo starts to spool timing is backed away. This sounds a bit dangerous to me. How close are people running to detonation limits with this routine? I would guess that the turbo/converter combination is such that spooling is not really a difficult problem to begin with.
I thought this way was the most common knowledge.
On gas I run as much as 46 degrees and 13.5-1. Some cars like 12.5-13.0 so I have to play with them a little to find what they respond to.
I run this timing below 100kpa. As the car builds boost I ramp the timing and fuel map closer to 12.5-1 when I launch. I do nor use a seperate map, I do it all on one map and just transition from boost building, to launch then to run. Since the boost is ever increasing, doing it all on one map is no problem.
