Advice on inter cooling an 85 GN????
ctflash1
Hey guys my name is Steve and was looking for some feedback on converting my hot air to IC. Should I or shouldn't I that's my biggest question?!?!?! If I should what route should I take a new motor or just convert what I already have? Any advice would b considered and appreciated. Thanks
Yes you should,unless you run straight methanol then you really don't have to. Just add an intercooler to what you already have I think it would be cheaper than doing a complete engine swap.
That's what I was leaning towards since I already have a bunch of upgrades on this motor. Do u think I should change my intake or can I do it by just adding an intercooler?
Convert and don't look back !!! With a hotair your choices are limited and the parts are more expensive. You can have a stock turbo for a 84-85 and only 1 upgraded size. As you may or may not know there a ton of options with a intercooled car. Aftermarket Hot air dp way more expensive and very few options. With so few hotairs made parts aren't easy to locate
