af reading sm maf 52 ???? way low wot ???
speedfreakv6
speedfreakv6
ok just took car for another test drive and notice af reading was at 1 at idle then only went up to 52 wot then car cut out !!! that is waaaaaaay too low correct ???? is zo6 maf ??? could it be bad ??? wot should be in 300 range ???
what are you reading the airflow on?
what are the settings in your Gen-2?
B
scanmaster was af reading ! and got gen2 set for ls1 zo6 maf and extender/pro ! i think this maf is shot came off nitrous huffen 6.0 gto that goot smashed !!! gona try to find another maf and see what happens !!! i could have sworn the other day maf was higher !!! but been so frustrate that could have over looked it !!!???? would that possibly cause the rest of my symptoms ??? also have iac issue but have spare one to put one tomorrow !!
