SignUp Now!How about 12.00 or little higher with alky.
A general rule of thumb is to shoot for 10.8-10.9 when running alky.
or 11.4-11.5 when NOT running alky.
You really tune it that fat on alky? This is really confusing to me. I would think with the cooling effects of alcohol that you would be tuning for numbers more similar to race gas.
The non alky numbers are what I would tune for, just surprised by the others.![]()
The more power and more alky injected the richer it should be. Under 500whp 10.8-11.0.1 is fine. it will make more power being leaner until it's starts melting stuff. There is not much to be gained going a little leaner. Maybe a few hp. It will easily tolerate being a lot leaner on a dyno because the time under power and load is not like making a full pass through third on the pavement. I run 10.4-10.6 for 650whp.I think i'm going to shoot for the 10.80, that will help me avoid lean spike when shifting also. what the hell if i get it to fat it's much easier to replace the plugs rather than pistions.
If you go leaner and are making any power you will soon find out how to replace pistons and repair burned decks/ melted heads and pistons. Non oxygenated race fuel can be run much leaner. Pump gas is oxygenated and you are replacing part of if with methanol which will further require richening.You really tune it that fat on alky? This is really confusing to me. I would think with the cooling effects of alcohol that you would be tuning for numbers more similar to race gas.
Unfortunately you can't be sure what% of pump gas is co-solvent so your stoic will be varying every tank of fuel. It's easier to use the gasoline table and just shoot for conservatively richer targets.Adding alcohol skews the WB reading. For a WB to be truly accurate in reporting AFR, the ratios of hydrogen to carbon (H/C) and oxygen to carbon (O/C) ratios of the fuel are required.
The WB controller needs this information to correctly convert the sensor reading into an AFR. Even a Lambda value would need to be corrected once off of stoich.
Adding alcohol to gasoline changes the H/C and O/C ratios. Thus skewing the reading.
RemoveBeforeFlight
