so those stage 2s are running stock fuel lines to !!! Thats unbelievable![]()
One was still on stock fuel lines, the other two were not.
Mine still has stock fuel lines!
I'm kinda partial to my automatic switching dual fuel system I made for my car. It simply works.
Ya ya ya...alcohol provides cooling for better horsepower....well....all I have to do is turn the boost up on my C16 and now I've equaled my HP gain to your HP gain....now, how are alky guys gonna beat that when you can't turn yours up anymore due to detonation?![]()
I thought the 120s were hi z and didn't require a modded ECM, therefore you will be ahead another $200. In the black!
Dual fuel system...Total cost...Total labor time...:wink:
E85 injector swap cost... fuel pump cost.... fuel line cost...install time...:wink:![]()
Here we go again...
Alky simply works.
Here's another good reason to run E85!
YouTube - 1464 HP Grand National dyno
Car made over 1600HP on 24lbs of boost!
Yes it does, BUT...if it works so well, why doesn't the super fast guys (170mph) run 93 octane and alky? Razor already stated the best time was only in the lower 140's. I believe I've seen TR's run way faster than that on race fuel. Until someone goes faster than 143mph with 93 and alky it isn't the best fuel...now is it?
To Grumpy,
This thread is about the best type of fuel, not about how my car compares to your car. But, if you want to compare my car to your car...I was running mid 6's at 107mph in the 8th mile back in the late 90's...without ANYONE's help. I had no internet and I knew no one personally that I got my "go fast" information from...I done it all on my own. Can you say you've done the same thing with your car? If you can...then good for you.:smile: But you sure do post a lot about Russ doing this-n-that...which is fine. He probably does performance tuning for a living...I don't.![]()
Intersting points.
How many 170/Super fast guys you see running on the street with E85 in the Buick world?
To Grumpy,
Maybe a poll would have been a better idea.
Maybe a poll would have been a better idea. Pro's and con's for both. Thing is, if you plan to build it, you have to understand the pros and cons.
nah !! Its to hot to go out racing so we need entertainment to keep us inside with the AC :biggrin: I think the E85 is goin to appeal to the mid country guys that have stations everywhere. to me race gas is out of the question. Not goin to spend $50/$75 anyway every time we are goin to race .
