Ok GOOOD discusion/ operation for Dummies.
I needed this info and still have some Q to put on this thread..
We use the time base mode to control run.
The Boost sensor is on the VG.
We have the CO2 bottle controlling the VG.
I guess that U as me are confused by the guesswork in TARGET PSI vs INTAKE MANIFOLD PSI, And we´re still guessing about that damn "TARGET PSI" without that right the ramp and time is useless
Question #1
Is it posible to logg the intake pressure (via intake mapsensor) on AUX channel and still controll the timebase mode on VG with boost sensor and CO2 ??
Another Q #2
HOW much slover would the controll system bee IF we set the Boost sensor to the intake manifold instead of the VG??.
We would still controll the VG with CO2
Question #3
When in LAUNCH mode, is it possible to delay the activator signal when relising the transbrakebutton so the chassie gets time to reakt BEFORE the timebase mode starts its sequence??
Yet a Question #4
How manny controll this unit by intake?? or VG??
regards Anders.
Ok sorry I´ll try it like this then.. the language difference and the way of building sentence can be a hazzel, didnt mean to confuse U![]()
Dusty. I really don't know a whole bunch about your combo, but is that two 50mm gates controlling two ?mm turbos or a large single?I log Co2 pressure on the wastegate with my XFI system. This lets me see the MAP reading as well as the Co2 psi.
There is no reason to use the AMS to control intake pressure directly. All it takes is a few passes to get a feel for the amount of Co2 psi needed for the amount of boost you wish to have.
If you have twin turbo's. The target pressure will be very close to your intake pressure. With a single, it's more sensative to back pressure. For example. With a 5# spring in the wastegate. 20psi of Co2 may net 20 psi in the intake. 30psi of Co2 may net 24psi in the intake. It could then take 40psi on the gate to produce 30psi in the intake. Once you get a handle on it, the controller works flawless.
Regarding your launch question.
You can maintain a very low boost for a long time after launch, BUT this depends on your wastegate size. If your wastegate is too small, the turbo will make more boost than you want, even with 0# on the gate.
To test, set your AMS target psi to 0# and the time at 0.00. Make a pass, this will tell you the lowest amount of intake psi you can run. It could be 5# or it could be 17#......it all depends on the proper sized gate for you combo.
I can launch at 10psi with a target psi of 10#. It will hold this boost for then entire run if I want. I have to run 2 50mm gates to achieve this.
OK. I'm getting the impression that you're making this harder than it needs to be. Let's start out from the beginning.
What do you want to accomplish with the intake manifold pressure?
It appears you want to launch on 7 psi MAP and then have it ramp as quickly as possible to 20 psi for the rest of the run? Is this correct?
Never mind the controller for now. Just outline what you want the intake pressure to do.
Ok, We have found a way to solve the loops..
Thanks for all good info in this thread Don![]()
