brake pedal seems to go away,what i mean is it has a solid pedal but if you hold the pedal with slight pressure it wiil go to the floor , pump it up and pedal comes back. could it be air in system?? a little info; installed line lock bled all 4 wheels brakes where fine line lock went bad installed new one and just bled front only, any thoughts??
