SignUp Now!I assume you would run more timing for the higher octane race gas and just less alky?
Usually alky likes less timing than race gas combos would, if you keep it that way you probably would slow down..
Am I on the right track??
Thx
this is for white t's quote of running lower timing and alky!!!!!!! my car ran leaner 770 o2's on 23/21 timing and 25 psi of boost with just 93 and alky. and 820's with 28/24 timing and 25 psi of boost and 93. go figure!!!!!. maybe the egts' were higher with the lower timing ????
You really need a wideband to get accurate a/f's. Adding timing in most instances raises the mv though. I dont like guessing on the O2 numbers. Widebands are very cheap these days.
