turbo6randy
- May 25, 2001
My engine is .040 over girdled and stock crank. Running TSS in 07 hurt my engine. Turned out #3 cylinder was cracked. Put a sleeve in it. Ran only DIY alky since then. Pushed a couple head gaskets on #3 so I decked block and heads. This year preparing to run TAI thought I blew a head gasket but it was the number 1 cylinder cracked. Piston was scored. Injectors checked good. Block was supposedly sonic checked before boring.
Wondering now if my ring-gap was to tight. Or if the sleeve in #3 contributed to my problem. No. 1 cylinder should not lean out.
Randy
Randy
