SignUp Now!As Dr.Evil would say "just shushhhh".Originally posted by BLACK6PACK
If this is the same one they have been making, I would run, not walk, away. EVERY, and I mean, EVERY person I know that bought one had problems with the puck sticking. They would send it back to ATR to have it fixed, even though ATR claimed there was nothing wrong. It would work for a couple of weeks and then get stuck again. Stick with the one that works and get a THDP.
Originally posted by Intercooler
As Dr.Evil would say "just shushhhh".If you haven't used it ya can't knock it. My .002
Yes but I have come to the conclusion that some could F-up the most simple of modsOriginally posted by UNGN
You can't deny people haven't had problems with this pipe. Over 20 people on this board alone. One as recently as a couple months ago. Who knows how many people are out there without internet access that have boost flutter problems and have no idea what is causing it.
It apears the reason bleed style boost controllers seem to cure the boost flutter is because rapid electronic solenoid cycling can cause the puck shaft to bind.
As for fit, once the original downpipe have been removed, I can install my Terry Houston DP at the track in about 10 minutes, without jacking up the car. I've done that more than once for back to back comparisons.
If you need to use a cat, I would just keep the stock downpipe and swap out for emissions test. A cat will flow less than stock elbow.
Buy an ATR THDP copy if you want one, but you can't go wrong with a Terry Houston.
Yes but I have come to the conclusion that some could F-up the most simple of modsJust my .002
Yes but I have come to the conclusion that some could F-up the most simple of mods Just my .002
