8 84ttype-hotair New Member Joined May 28, 2006 May 30, 2008 #1 what turbo is this ? with some detals on it like hose power and surrporting mod thanks
J JZ 97 SS 1500 Turbocharger Engineer Joined Jul 2, 2001 May 31, 2008 #2 More then likely you are refering to the covers casting #. Should say M24 on it. For the spec on the turbo you will need to remove the comp cover and turbine housing and meaure the actual wheel. Only way to tell what it is.
