Re: BRAKE SYSTEMS
Originally posted by POWERBRAKEBOB
I'm not sure what you mean by "fail" All of these systems use dual master (front and rear) separation. Total failure could only be caused by oil being poured in the master.
Has anyone had their p/s pump fail on the highway? Maybe.
Speaking of FAILURE, some of your guys have blown the vacuum hose off of the vacuum booster under boost.
That is EXACTLY why Buick did not install vacuum boosters on turbocharged cars.
The term GRAND NATIONAL was actually a race series. They did not use vacuum boosters in that race series.
I'm still don't understand why the close mindedness about the hydroboost. When those cars came out in 1983, Buick installed HYDROBOOSTS from the factory. No one that owns one of those cars complains about them.
As far as 572's and 540 Hemi's, there is no pro class for them to run in.
The G.N. guys like to stand on the brake and the throttle at the same time and watch the boost guage go up. If you blow the vacuum hose off at the line. the car won't hold at all.
The vacuum check valve is just a thin flap of rubber that wasn't really designed to hold pressure, and will eventually be forced inside the vacuum booster.
In order,
Fail:
To cease functioning properly: The engine failed.
In this case, blowing a hose, losing a serpentine belt.
Yes.
One individual that didn't bother using a clamp on the line, and one with a check valve, that failed.
While Buick didn't, Pontiac did. I also believe the Turbo Sunbirds had vacuum boosters.
That's what I said. They used manual brakes, with no power assist.
No one complains?. You're now stating as fact that there's never been a compliant?. Hmmm
Maybe, your the only hyping them, since that's your business. BTW, what did you say a Hydroboost system costs?.
So then, are we to assume, that you also haven't sold any to any Pro Stock, NEXTEL, F1, LeMans Series, Sprint car, old Can-Am racers?.
Blowing a hose off, is a possibility with your system also. Ones vacuum, the other oil's down the track. Have you documented you claim of the check valve failing in such a manner?. I would have thought that GM would have thought of something like that, when they used a vacuum booster on the 89 TTA.
So that's how, the GN Guys, stage, gee, what a concept.
BTW, one other item, is with the higher assist the less *feedback* there is. Are you familiar with the term threshold braking?.
BTW, do you have a data log, of a Hydroboost equipped GN (stock weight, only braking improvement the hydroboost), stopping?.
If so, I'll go out and log a 80->0 *panic* stop, and we'll compare numbers, OK?.
Up for the challenge?.
I'll also gladly get it notorized, if that's a concern on your part.
