ttypewhite
- Oct 1, 2001
My guess would be 790 @ 830ft of torque.
Westside,I have a decent sized fan there.But that was also a 3rd back to back pull,so there is some heat soak to consider
I wasnt done yet thoughIt had a little more.
But after a phone call,there is a possible big change in the future![]()
I have a BA cooler 5 inches thick, it works great, i have had 5 different front mounts in my car, BA sent me the cooler and said if you dont like it or want it send it back , i installed it and 6 months later they sent me a bill and the price was 300 bucks less than the price i paid another vendor for the one i took off, they are great guys to deal with, i dont care who goes fast with what cooler i didnt buy it because some other person has one, as of this time it will be the last cooler that i will ever own, good luck on your purchase,
Why are they great guys to deal with? How are they "great" guys to deal with? Did you give them data and feedback they can use? Did they make refinements based on your input? Or are they just "great" because you got a "great" deal on your IC, one that others most likely won't get?
This IC debate is ridiculous and nauseating to boot. I know nothing about the BA IC but looking at the demensions the thing looks to be the same size if not larger than a CAS V3. The V3 has been into the 7's and on several 1500HP cars to date so I would expect the BA to be at least capable of 1200HP if not the same as a V3. To take an IC that is dimensionally the same as a cooler capable of supporting 1500 or even 1200HP and comparing to one that is capable of 700HP is ridiculous.
My understanding is that the standard "Jack" was built to "replace" or compete with a CAS V2 IC, which it did admirably, especailly since it was no longer available. The CAS V2 was never intended to be on anything faster than 10.50's but it has gone as fast as 150mph. From what I've seen the "Jack" is very well capable of performing to the level of a mid 10 second car which 90% of the people out there buying one are going to use. This IC shouldn't be compared to anyhting other than a CAS V2, Eastern Perf. FM, PTE std FM. or anything comparable in size and weight. I think when looked at this IC is going to be comparable to all those in its class and even better than some.
When comparing the "Jack" to a V1 (notV2) it is significantly lighter meaning it is going to have significantly less cooling surface area so it is essentailly going to be a smaller IC even if the core surface area is the same.
In determining the proper IC for your combo you need to take into consideration the inlet and outlet temps (IC efficiency which changes from one combo to the next) along with inlet and outlet boost pressure. This will change from car to car and combo to combo and day to day depneding on weather. Another thing to remember is you need pressure drop a across the core to have cooling. A straight pipe will have zero pressure drop but no cololing either.
this is america where you can buy what you want believe what you want and i spent four years of my life defending that right, so when someone treats me with respect and i have their trust i may call them great people to deal with and i dont have to answer or explain my actions to anyone, good luck with your BA cooler i hope you like it as good as i do the one i have,:biggrin:
I did not bother to read through this but does BA have a website, email address etc?
P.M. me if you want.
Thanks.
