A friend who is a novice painter told me when applying base coat clear coat paint that the base coat must be sanded before applying the clear. In my research (I'm a wanna be painter) I found that when the dase coat has flashed then you apply the clear coat.........no sanding. After the clear has dried then you color sand...Of course I guess it depends on the paint manufacture's instructions. So, do you sand after the base coat or not?
Thanks guys!
Woody
Thanks guys!
Woody
