SignUp Now!You have to trim the stock bathtub gasket to remove the actual intake ports, but leave enough so that the little "hooks" still grab and enough gasket left to hold the valley tray in place. I also cut the 1200 enough to clear where the bathtub gasket needs to tough. I cut the 1200 between the water ports and intake as well as in the EGR area. I would not sandwich them. I really like the sheetmetal valley pan in those pictures. Seems fairly easy to make.
Russ,
Looks good! Where did you have to trim it at? Near the pushrods? Glad it worked out for you. Talk to you later. Jeremy
