- Feb 14, 2002
Black Sunshine,
On a technical level, I see in your sig that you are running 42.5lb injectors. A double pumper would be massive overkill for those as you would be capable of delivering about +120gal/hr fuel rate, and only using a little over ~40 gal/hr at most. The return line would be flowing twice as much as you could use at the engine even when you were at 100% injector duty.
With those injectors you would be absolutely fine with a regular walbro pump and good solid electrical wiring.
