I'm still a little unclear about why 2 step rev limiting doesn't work with the stock setup. Where is the sync being lost and why?
think of it this way.
the coil pack is a sequencer and charges and fires the coils one after another in response to the EST signal from the ECM
When the EST signal goes from 0 volts to 5 volts, the ignition module begins charging a coil. When the signal drops from 5v to 0v it fires that coil. On the next pulse it does the same to the next one.
A 2 step prevents some pulses from getting from the ECM to the ignition module
When this pulse is not received, the ignition module does not generate that spark, but also does not know to advance a coil.
so when that pulse is dropped, the coil module is then one cylinder behind in the firing order...... until the next cam sensor pulse is received and the sync order is corrected.
is that any clearer?
Bob
