We sell this one.
STAINLESS CATBACK EXHAUST I installed one on my own GN replacing the Hooker with Aerochamber muffs I had on it. Actually a bit lighter than the Hooker setup, no drone and sounds nice.
Installed it on my back in my garage, would be a lot easier with a lift. My car is lowered quite a bit and had to trim a couple of the pipes to gain clearance going up and over the rear axle.
I suggest using stepped band clamps at all connections instead of the supplied clamps, that way the system can be easily disconnected if the need arises and makes it easy to change positions of the pipes as you install them. I have it supported with 6 hangers total. One in back of each muffler, the welded tab on the rear axle pipe to the factory hanger and then an additional one on the tailpipe. I am NOT using the factory cat hanger and have a band clamp at the dump pipe connection to the down pipe.
If you eliminate the cat hanger you will have to shim up the difference on the trans mount to keep your driveshaft angle the same. I used one of the HR trans mounts we sell as that has a shim included with it. Have not had any issues with eliminating the cat hanger. With the hanger setup I mentioned earlier the system pretty much supports itself, not a lot of pressure on the downpipe.
