I would much prefer to use a stock style oil return rather than tapping the oil pan. Motor is out of the car, heads off, oil pan off sitting on an engine stand. Don't want to dissemble any further than that.
I'm thinking either do it upside down on the engine stand, with a shop vac on the inside of the lifter valley where the drill/tap will break through, or right side up using the same method and rags at the bottom of the valley.
Opinions? Tips tricks?
Also - to make doubly sure, 23/32 bit, 1/2 NPT thread, correct?
