A lot of times you will not get the exact length pushrod you need. They usually are in .025 increments. The rockers have a window of adjustment in which they will work and oil correctly. I set the rocker adjuster on the low end, measure and use that number or as close to it as I can get. 1 turn on harland sharps are .050 so 2-3 threads exposed lets you set it at two and have .050 to adjust your preload with. I hope this makes sence--LOL---maybe we can get some guys with better words to chime in and further explain
