Tim here are some things to look for:
1) Valve adjustment. Make sure that they are done correctly and no valves are left open.
2) If you still have your stock balancer, use that as a reference for the zero mark if you know where the key weigh is on your new balancer.
3) Did your new balancer come with a reluctor ring on it, or did you put that on after getting it? Check the reluctor ring with the new balancer to the old balancer. The postion of that ring has got to be exact.
4) Varify your firing order on the plugs in relation to your coil pack. (also make sure the igintion module is plugged in
5) double check your crank sensor and make sure that the reluctor ring did not ding it.
6) simple fuses your the dash or the fuseble link by the battery
Good luck Tim, let us know what you come up with.
