yep youll need to check the timing witha dialback timing gun ,i did find one that was dead on but from what i hear thats not the norm , mine was off 4 degrees (showed 32 when 28 was being commanded by fast ecu). i just ran across one that is atleast 8 degrees out the other direction , esily fixable with fast or xfi , if your on a chip like TT you need to check it and then you can have a new chip setup to correct ....or reclock the reluctor ring
