SignUp Now!This engine came out of a NA Regal. Bison is it safe to assume that there is no turbo crank inside? Also whats the best approach to change over to a turbo application? I have had no experience with different deck heights or non 109 blocks. This is this winters budget build!:biggrin:
I just had this block rebuilt with a turbo crank and pistons. If you want a copy of the machinest build sheet let me know. Brad
Bison does milling the deck make it possible to use the 2 dot stock rods from a 109? I'm thinking about using the the NA crank and a set of 2 dot rods I have. Will that give me the right piston height in the bore? I'm mostly lost in this procedure. I have 3 109 blocks but want to use the block that came with the car.
it will have an na crank. I'd run it if i was only looking for high ten sec power. The pistons will need replacing and the assembly will need balancing. Mill out the first 3 threads in the deck on each hole and be sure to use the correct length fasteners. It may use a different cam bearing dimension but i can't remember for sure
What I posted is exactly what I meant. Full float and start with a smaller id bushing and increase the center to center length to get the piston near the top of the bore. The discussion was about a 3.8 bore NA engine. Nothing about a 4.1. When I got a lot of the 4.1's in the mid to late 90's about 10% had been remanufactured and had 3.8 NA cranks in them.i think you mean counter bore
op seamed confused to what you meant (SEE POST #8)
also i thought all 4.1 's had the turbo cranks? Rolled fillets on mains and rods?
