- Mar 1, 2005
This really should be in the same thread. I am going to try to leave it here for tech purposes. If it turns into a circus like the other one I will simply combine it again....
SignUp Now!This is a 3rd one. Not the one you closedShane, I closed one thread. Who opened it, again?
Yes, this is yet another thread. We will see how it goes!Shane, I closed one thread. Who opened it, again?
Wow! I guess I need to keep up!This is a 3rd one. Not the one you closed
That's not the point. The point is he shouldn't have to lolA leak down test will show you if combustion pressure is getting past the rings, valves or a crack. If it's sneaking past the rings, that would add to the normal engine oil mist that in the crankcase and pressurize it sending oil out the breathers. If the leak down is negligible then you have an issue with the oil and mist being slung on the vent tubes and vents.. There are several ways to deal with that. You can do a search for that. Tons of threads on pcvs, catch cans, grommets, valve covers, valve cover baffles and styles of vents. If the leak down high then the engine needs to be pulled and torn down. Dude, what else do you need to hear?
Any picture?You can run both the RJC and stock PCV at the same time. Using the RJC as a check valve before the PCV.
Any picture?
Ok so it doesn’t seem to bad to do a leak down test. I just have to get the stuff. So you just do one cylinder correct? Make sure #1 cylinder is top dead center correct? Then put shop air into #3 cylinder. So take out two spark plugs? Right?
