- May 27, 2001
John Wilde said:Guys,
I looked again and the car has the upper strut mount in front.
He cut out almost everything else but with the Mustangs having the Uni Body I think this is Outlaw Legal.
86brick said:Hey John, on the Clash of the Titans message bd they are saying the turbos are twin 88mm Turbonetics...
http://www.theclashofthetitans.com/snitz/topic.asp?TOPIC_ID=426
86brick said:Here are the rules for Orlando....
"- NO FULL ROUND TUBE CHASSIS.
- Struts must be stock type, originally available on the car and
used with the stock front frame rails or a direct bolt in
conversion with stock front frame rails."
Also, would have to weigh 3200lbs to run the class because of the clutch and the twin turbos....
John Wilde said:How do you like the twin injectors per hole?
Looks like a 160 and 83....
Duttweiler has also used this set up!
John Wilde said:The strut on a Fox Bodied Stang Bolts to the Caster Camber Plate in Sheetmetal on the top and to the spindle on the bottom. I think that this car fits the rules.
3200lbs should not be hard with all the extra weight up front. If they let him run in texas he will run in orlando.... Unless it is drag radial where twins were outlawed....!
John Wilde said:Funny thing is that Rick was not going to play this year.
It sure did rule out Hartline's Boy though.
John Wilde said:All 88s are not the same....some are 98s!
