I've got an 80 turbo control if you're interested. If all the wiring is there it should be plug and play for you.that´s right. The car has got a 1980 engine. No ecm on it. The original carb and turbo are on it. But the esc module is gone. The wiring is still in the car.
I would run the non turbo dist. with msd boost timing managemant and an audible after market knock alert , In my opinion the factory knock retard sytem is junk at best almost 40 yearold electronics. Not running it on my new motor.I have a origninal no turbo distributor with vacuum control. Should I put this in the car and change some wiring ? Is this possible?? How do I´ve to set the timing? Just like haynes sayes. 900 RPM 15 degrees bpd?
That's a general question for a very ugly area. Anywhere specific or of anything specificDoes someperson have a pic or diagrahm of the underside of the dashboard of an 87 gn
