I have an 87 GN with a 5487 204/214 edelbrock cam ,ported heads /thrasher chip,hot wire kit with walbro fuel pump,and 55lb injectors. My question is. Will a T3/T4E-bb turbonetics turbo work for this setup?
WELCOME PILGRIM!!!
You will have to include more info on the turbo size. They need to be spec'd for your performance level. Also, I would consider replacing the thrasher chip w/a turbo-tweak. a much better option.
WELCOME PILGRIM!!!
60-1 comp. wheel 63ar fi 57 3inch intake 2.0 inch outlet 3 inch downpipe ported housing. Hope this is enough info. And will be ordering a turbo tweak chip.
I had a 60-1 on my stock long block GN. Spoiled a little slow on the street, but was fine at the track with a restalled D5 converter. Depending on your converter, I'd say you're ok. Check with Bison here on the board. He could steer you in the right direction and make you a good deal on a turbo.
