SignUp Now!So, Still. What can a factory GN engine handle?!
And could the buick engine have shorter pistons, with longer rods, and rev faster and higher? Wouldnt this be a good thing, or would it be like the supra and have no low/mid torque?
So the complete factory motor can handle about 600 whp. And, if you were to get an internally balanced crank, and a girdle, would that help a lot to get more power out of the engine if everything else is stock?
Eagle and CAT both grind their forgings out of the same blanks. The outcome is slightly different on each. Check out Full Throttle's crank kits. They are a bargain compared to what it cost to build a high hp bottom end 5 years ago. These are not drop in and go. The bearings need to be chamfered and the cranks need to be checked over thoroughly before assembly.Who makes a forged crank with stock specs?
that would be awesome... LSX V6!!!
An I6 has lots of advantages over a V6. Its got 7 main bearings as pointed out vs 4, it has single rod throws so you don't have to have a split pin for an even fire motor, there is no V in the crank case to introduce a weakspot in the middle, and the motor is naturally balanced since it has as much weight going up as comeing down which makes it very very smooth and easier on parts.
A V6 just has a nasty tendancy to eat crankshafts with the split pins and an oddfire motor introduces all sorts of other bizarre fatique issues from the nasty vibrations and irregular bearing loading due to the gaps in the firing order.
If you look at the Supra motor it probably has a shorter stroke and deck height that drops the requirements of the rotating assembly meaning a shorter rod, like the Series II/III 3800 and a shorter piston.
thow in valvetrain harmonics, pushrod flex and other issues and the engine just isn't designed to rev like that because at the time when it was designed the American market wanted grunt, not high winding engines that needed steep gears and delivered poor off the line acceleration.
i knowdon't worry, i've already started a thread at gminsidenews, and received good feedback New V6 needed - GMInsideNews Forums. i've also told the general himself! they couldn't say they liked it, because that would reveal future plans...we can only hope.
What if they BOTH had 800hp and 600ft/lb torque? Would it be an even race then?
I forgot to mention. Doenst someone sell a stroker kit that is meant for stock bore, and it is already checked out, and balanced, and can be dropped right into a block?
First off the 3.8 and 3800's are 90º V6's not 60ºs, but thats irrellevant since any evenfire V6 would need to have split pins. The reason for the V6 is showing up is due to packaging like I mentioned due to its space limitations. The rest I just don't feel like responding to.o rry?? is that why toyota put a new v6 in its lexus? all modern 60° V6 have split pins. it helps intake and exhaust tuning. another idea stolen from buick, which it doesn't exploit.
It's not gonna happen...both engines have diff displacements. Even if they did, lets say they'd '60 the same time then it would come down to the weight. Too many diff factors to give a fair comparison. It's peaches & apples here ! About the kit contact Dan @ DLS he should clarify ur doubts about stroker kits & guide u in the rt direction
DLS? Do you have a website address, or phone number? Both preferably.
