Stg11 Cam bearings
Cam bearing for the 109 blocks and the 4.1 Stg11 offcenter blocks are different, the prefered method ( by the several builders in this area that built a lot of V6 buicks for the Busch north cars)in Stg motor applications is to use the Clevite 77 # SH-1360 bearing, it,s the wide bearing ,you,ll need to order 4 of that part number, I get them through NAPA, takes about a week. If you order a set for a 4.1 (14bolt pan block) you,ll get 1 wide and 3 of the narrower bearings. Cam bearing life with all 1360 bearings is sure to be extended, especially when using big roller cams.
Something to remember , if a Stg11 block spins a cam bearing or two and needs repairs the cam bearing bores can be bored out for the .020" larger dia 109 bearings , two sets would be needed to complete the job.
9sec.
