I believe it was the was the way Comp case hardened the cams. A cast steel cam is not hard enough to withstand a steel roller and spring pressures unless going through a hardening process. I believe these cams where wiping out in less than 1000 miles.
There was lots of interesting conversation on the board just prior to it mysteriously crashing and losing all data including all back ups.
Then again I am sure it was an improper installation and break in procedures right Neal, lol.
Hey if we are going to open up old wounds might as well go all the way right lol?
In all fairness I believe the new ones are fine and proven at this point. For some of us that were around for the original "budget" roller cams a cast roller cam isn't as appealing as it once was.
I built a girdled 109, steel crank, carrillo rod, solid billet cam motor back in 1999 and never bought a budget roller. I used a Weber style cam setup on the cam nose on that motor. The reasons I didnt care for it was that it was the torrington bearing restricts oil from the first cam bearing which feeds the cam and distributor gears. In addition I believe he was also machining material off the back of the cam timing chain gear so a replacement would not be as easy to come by. You used to have to weld a piece on the timing cover for the roller bearing on the cam nose and setting the end play was a real PIA. I am sure there have been upgrades and changes over the years but those were the issues I didnt care for with the Weber set up back then. Like Nick said above the Danny Bee setup is full proof simple and the best set up you can run IMO.
