Here is what Cal told me to do:
I put a light smear of Permatex over the deck surface, install the gasket, then permatex the head surface and install it. I then torque the heads let them sit overnight then retorque.
Yes, use Ultra Copper. I have used Ultra Blue several times, but the copper doesn't dry as fast. I brake clean the block, then put a light smear on the entire deck surface. Just do enough to cover it, but not be transparent (if that makes any sense). Then I set the gasket in place and take a clean rag and wipe all the extra sealer on the deck that is inside the bore opening in the gasket (you will see, the gasket bore is 4.060, while your engine bore is probably 3.820). I make sure the gasket is pressed in place. Then I go to the head surface. I coat it just like the deck surface, doing everything OUTSIDE the receiver groves.
Torque it in the sequence on the package. I usually do it 30#, then 45#, then 60#, then 75#. I then let it set overnight and loosen one and then retorque it, then do the next one, etc.. I do them in the order of sequence. I use ARP thread Sealer with 10W30 oil under the washer and bolt head
Cal Hartline
