If all Buick V6 blocks were SG1 blocks,I don't think any knowledgeable engine builder would use words like strong or robust to describe one after seeing one for the first time. When viewed from outside of the Buick community,these blocks would fit the description of weak. The two types of block we have here are weak (86-87) and weaker (all earlier). There is a notable difference between the weak and the weaker,or so we assume it's weaker. This difference is easily seen when viewed from the bottom. Because of this easily seen difference,I would guess that the earlier weigh less.
We can countersink the head bolt holes in the deck to help that situation in the weaker and a girdle helps them all. I wonder which blocks would generally fail first when tuned by a very meticulous and experienced tuner that would never allow for detonation. I think we would be surprised to see how equal there strengths might be or,at least,how much power the weaker could safely and consistently make. Then again,this car is all about surprise and has been from the beginning. The biggest surprise is how much power these weak blocks can handle.
I wonder how many blocks would still be with us if they had all had forged cranks in them. I think the forged crank is something that allows us to produce more power while exerting less destructive forces on the block.
Are these blocks weak. In the general scheme of things,I say yes. The question I ask myself is how much abuse do these blocks see that is caused by us or could be lessened or eliminated. I think crank flex and detonation are bigger players here than block choice. I think all of these blocks tolerate more power when they have a forged internally balanced crank in them and I believe this to be the most important part of the mechanical parts chosen.There is another force that a weak block tolerates less than a stronger one and that is the twisting forces that it has to endure when the engine and transmission assembly is held in place toward the front of the engine. This does the same thing to the block as wringing out a wash cloth. A midplate and stock motor mounts would remove this stress from the block. Some Olds guys do this because of their weak blocks. A step that we can all take in this direction is to use the RJC brace and stock motor mounts.
