Hey,
I was thinking about my hesitation and bucking problem last night and starting debating with myself about the cam sensor. Couldn't sleep!
When you set the engine to 25 degrees ATDC then find the voltage change point it seems to me that it doesn't matter where the cam sensor is physically compared to the cam.
Does it matter where the wires are pointing as long as you set it at the voltage change point?
Anyone have some thoughts / discussion on this.
By the way, should the dimple on the sensor gear line up with the tab on the rotor?
