without wastegate hooked up all I could get was 13# seems like something is wrong with actuator. I really don't think its boost creep but could be wrong
How many turns of tension do you need to add to that relief spring to make the HD act as a regular actuator?Grab a spring and some washers from ace hardware.
Ok. What psi am I looking for?You'll need to use a compressor with air to find that out
Thank you.Apply 14psi to the regulator and see when she moves
What size was the port for the 6265?I had both a 6262 and a 6265 and had to port the housing on both...Going to bet that will be the case here
